aller un petit copié collé
SUZUKI Make/Model: GSXR600
Year: -02
Number of Tb: 4
Inside Diameter: 38mm
Center-Center (left to right from behind): 80-80-80mm
Overall Length: 83mm
Outside Diameter (intake): 44mm
Outside Diameter (filter): 45mm
Separate casting: Yes
Injector Make/Model: Keihin KN4, 0J07 AAA A
Flow Rate (45psi/100%): 240cc/min?, 13Ω
Fuel Rail: Alu casted, Inside diameter 6mm (9mm in the ends)
Additional Info: sec. throttles controlled by ECU.
Make/Model: GSXR750
Year: -98, -99
Number of Tb: 4
Inside Diameter: 46mm
Overall Length: 91mm
Outside Diameter (intake): 54mm
Outside Diameter (filter): 54mm
Injector Make/Model: Keihin,
Fuel Rail Inside Diameter:
Additional Info: No sec. throttles.
Make/Model: GSXR1000
Year: -02
Number of Tb: 2
Inside Diameter: 42mm
Overall Length:
Separate casting: No (dual Tb´s)
Flow Rate (45psi/100%): 230cc/min
Year: -03
Number of Tb: 2
Inside Diameter: Tapers from 50 to 42mm
Overall Length: 90mm
Outside Diameter (filter): 53mm
Additional Info: Pic without secondary butterflies and fuel rail.
Make/Model: GSXR1300 (Busa)
Year: pre 2002 ?
Number of Tb: 4
Inside Diameter: 42mm at injector end, tappered from 51mm at air horn end
Outside Diameter (intake): 55mm
Flow Rate (45psi/100%): ?
Fuel Rail Inside Diameter: PA66-G35
Additional Info: no secondary butterfly
KAWASAKI Make/Model: ZX6R 636 B1
Year: 2003
Number of Tb: 2
Center-Center (left to right from behind): 75-75-75mm
Outside Diameter (intake): 52,6mm
Outside Diameter (filter): 50,8mm
Injector Make/Model: BOSCH 280031V
Flow Rate (45psi/100%): 245cc/min
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: GPZ1100
Year: 1981-198?
Number of Tb: 4
Inside Diameter: 32mm
Center-Center (left to right from behind): 80-100-80mm
Overall Length:
Outside Diameter (intake): 40mm ("serrated")
Outside Diameter (filter): 40mm ("olived")
Flow Rate (36psi/100%): 180-200cc/min, 2,5Ω
Additional Info:
YAMAHA Make/Model: YZF-R6
Year: 2003-2004
Number of Tb: 4
Center-Center (left to right from behind): 72.5-72.5-72.5mm
Overall Length: 95mm
Outside Diameter (intake): 52mm
Outside Diameter (filter): 44mm
Separate casting: Not exactly, but can be cut apart easily (fuel rail)
Injector Make/Model: Keihin ?? # 250031F
Flow Rate (XXpsi/100%): XXXcc/min, 11.7Ω , 12mH
Make/Model: R1
Year: -04
Number of Tb: 2
Inside Diameter: 43mm
Center-Center (left to right from behind): 78-78-78mm
Overall Length:
Additional Info:
HONDA Make/Model: CBR F4i
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: RC51
Year: 2000
Number of Tb: 2, 2 injectors per TB
Inside Diameter: 48mm
Center-Center (left to right from behind): 24mm (TB's are not parallel)
Overall Length: approx 40mm
Outside Diameter (intake): 60mm
Outside Diameter (filter): 70mm (not sure how filter fits)
Separate casting: Yes, TB's are independent, mounted to linkage bracket. Modification needed of fuel pipe and linkages to change spacing.
Injector Make/Model: ????/????
Flow Rate (XXpsi/100%): XXXcc/min, approx 11Ω , ??mH
Fuel Rail: Alu casted, 1 per injector, joined by solid fuel lines
Additional Info: Comes with MAP, fuel regulator, TPS. Has a manual choke mechanism synchronized to both TBs. Not sure how it works - fast idle bleed perhaps?
Make/Model: CBR600RR3
Year:
Number of Tb: 2
Inside Diameter: 37mm
Overall Length:
Separate casting:
Additional Info: Injectors mounted in cylinderhead.
Make/Model: CBR600FSi
Year:
Number of Tb: 2
Inside Diameter: 36mm
Overall Length:
Separate casting: No (dual Tb´)
Additional Info:
Make/Model: CBR 929
Year:
Number of Tb: 4
Inside Diameter: 40mm
Center-Center (left to right from behind): 80mm-80mm-80mm
Overall Length of casting 70mm
Outside Diameter (intake): 49mm
Outside Diameter (filter): - flat flange for airbox
Separate casting: 2 twin body castings
Injector Make/Model: ?? Marked as OK24 B
Flow Rate (45psi/100%): not sure. RUns at 50psi
Additional Info: produces 150bhp at 11,500rpm from 74x54 929cc. 11:3.1 comp ratio, 10 litre airbox.
Make/Model: CBR900 954 Fireblade
Year:
Number of Tb: 2
Inside Diameter: 41mm
Overall Length:
Additional Info:
Make/Model: CBR 1100 Blackbird
Year: ??
Number of Tb: 2
Center-Center (left to right from behind): 85-85-85mm
Overall Length:
Flow Rate (43psi/100%): ~335cc/min, 13Ω
Additional Info:
SNOW-MOBILE
ARCTIC CAT
Make/Model: ZR600 Snowmobile
Year: 1998
Number of Tb: 2
Center-Center (left to right from behind): 134.5
Overall Length: 105mm
Flow Rate (XXpsi/100%): XXXcc/min, 2.9Ω , 5.8mH
Additional Info: 2-stroke snowmobile, parallel twin 600cc, 105hp
source:
www.homemadeturbo.com
